Rare FIND!!!
Heebs84
 Green Bay, WI
FBB4B0E5-1DE6-474C-8697-021DC9B2375C.jpegB3BD1005-5AED-4163-93AE-CA13FF28784F.jpeg6ADC0D6C-E879-4790-93F5-8F7F330A50DD.jpegView attachment 3
Swapped rear diffs and found ball bearings instead of taper bearings. Any one see this before??
I have seen some rebuild kits for E85/E86 rear differential bearings which use two rows of ball bearings instead of the standard taper bearings (see image below). I am not sure what the reason behind using ball bearings instead of taper bearings and personally when I come to do my differential bearings I will be using taper bearings, but only because this is the stock/default bearing type.
They look like angular contact bearings, and would be pre loaded with either shims or a threaded adjuster. Probably lower friction than taper rollers.
My dad was surprised to see ball bearings. He’s a mechanic so he has done a rear diff or two 😉 My guess was that someone rebuilt it using an older rebuild kit or used whatever they had laying around that fit.
