Random bulb warning light problem
jamesgarbett
 South Manchester
Anyone know why this may be happening?
The bulb warning light comes on seemingly at random.
I've checked and all the bulbs are working fine.
Sometimes the light comes on and then goes off after a few minutes, sometimes it stays on the whole journey, sometimes not at all!
Is it something a dealer could reset?
Have you checked the lights? Some people had this issue when there was moisture in the lenses, it was down to corroded connections.
You could also check the sidelights - the bulbs in mine were loose, and one of the holders was snapped round the edge so the bulb moved... Leading to the bulb warning light coming on. Sometimes the bulb worked, other times it didn't. I had to replace the holder - fortunately I got a spare off a very kind member on here :thumbsup:
Moisture would do it too though...
