Ram Air Scoops -E85/86 all variants - Oct 2018
dans6490
So I now have 30 more of these, powder-coated black, packaged, ready to go. £40 delivered via Hermes.
Please PM name, address and I will reply with paypal address.
Any questions, please ask :)
Link below to previous discussions / threads about these:
http://www.z4-forum.com/forum/viewtopic.php?f=7&t=83675
Brief Description of what the idea is behind them:
Convert your stock intake system to a ram air type with our ram air scoop. The ram air system captures incoming air from behind the front kidney grill and forces it into the factory intake ducting. The pressured cold air increases engine performance and efficiency. Expect 8-12whp at 70mph winds. Note: Also fits non-M models.
Link to scoop this is based on (not copied...):
http://www.raceprecision.com/product/RPI-I1004.html
Description from a member here in an earlier thread regards fitting:
''For those that are asking about fitting: it's easy BUT... you need a long (300mm ish ) screwdriver and a stubby screwdriver. I didn't have the stubby and had to go to screwfix. Not just for the ///M - on realoem the intake ducting to the filter housing is the same for at least the SI variants, I didn't check pre facelifts as I don't have one.
Pull off right kidney, usual drill... grab the slats push up wards and pull the bottoms out. You will see the original scoop that uses plastic plugs, 3 of. Pull these out with grips and keep scoop for future sale etc. The oem scoop clearly isn't designed to catch as much air as possible.
I acquired dans scoop through another member and emailed RPI about screw sizes - 3x nickel plated 1"x8 self tappers. Hold the scoop up inside the bumper, and screw away into the plastic, same plastic the original was held on to. You can't go wrong as you can see the ducting and how the scoop will direct it. Stubby on the two screws that are aiming towards the rear of the car and the longun on the screw aiming parallel to the radiator.''
Glad to see my template living on :thumbsup: :driving:
This is a great little mod guys and gals! (Even better if you colour code them yourselves like I did, but that’s just my opinion :fuelfire: )
Still going strong mate, thanks again for starting this off!
I had thought the market had been flooded after the last set, so I wasn't expecting to be making more!
Mine arrived today thank you Dan, looks great quality very well made.
I'll try to get some photos when fitted hopefully Saturday or Sunday. :thumbsup:
Awww, mine hasn’t arrived yet :( lol
Hi dans6490
Are there any of these left for sale ?
I’d love to get one if there is
Let me know and i will pm you for my address and your preferred payment
Best regards Dave :thumbsup:
