Gah what a job. Cleaned off sensor, warmed glue in boiling water and rubbed off. Cleaned right back with alcohol and some 3k wet and dry.
Cleaned screen with microfibre, and thumb nail through it. Then cleaned with alcohol.
All good, so put new pad on sensor back, no bubbles, easy. Apply to screen slowly from one side and lap across. Bubble! Arse! Screen is not flat, and sensor plate is, so a bubble almost seems inevitable.
So, took all off and cleaned again, but this time did gel on screen first, perfect, but now bubble on plastic/gel bond. But this time pushing on back of sensor plate hard with a blunt tool meant I could remove quite a lot.
Still a few small bubbles but it's working now yay!
Still have one more pad, so semi tempted to have one more go, but might just see how long it goes as is for now.
Would like to say there is a knack to it, but I can't... I just can't imagine how you can put a flat item against a concave surface and get no bubble, fine if you could push it out, but any air gets stuck. Hmmm pondering using a fine wire now, so I can pump the air out by pushing on it, then slide the wire out. Hmmm.
