Rain and Light Sensor Question (Pic Included)
chriswoodward
Ottershaw, Surrey
So since I have bought my car the RLS doesn't seem to be working, the first function on my wipers only wipes across the screen once and that's it, full speed they are fine.
My Auto Lights are working though which makes me a little confused though I am not sure exactly how this sensor functions so maybe it is possible for one part to work and not another, I'll point out that DIS said the stalk may be at fault because the sensitivity switch doesn't make the wiper go across the screen when adjusted, is this correct?
I'm guessing I am not barking up the wrong tree and that below is the sensor? Also to me that looks like it is de-laminating is there a fix for this as its getting annoying to manually press down the wiper stalk when its raining lightly?
I would say that sensor needs to be sorted. Somebody on here fixed theirs but it was a long time ago so I can't remember who it was.
When the adjuster on the switch is moved the writers should move once if in intermittent mode, but this might not work due to the sensor.
Forgive my resurrecting this thread, but the same issue is alive and well on my Zed. I found that the sensor appears to be de-laminating (roughly 33%). The light sensor appears to be working as advertised but the rain feature is DOA. Anyone with a resolution?
Hello
The sensor is knackered or has started to fail when it looks like this .. when mine failed the whole wind screen had to be changed
Luckily for me I had a warranty and the dealer changed the screen
regards
Thank you, Mr. Bond. Replacing the entire windshield appears a bit extreme. Depending upon how the sensor is laminated on the windshield, simply re-applying either a laminate or using heat should suffice, although heat might damage the sensor.
Mine was like that was going to try and fix as you can buy the new adhesive that sticks the sensor to the screen apparently it's cheap too but a motorway journey later and flying piece of high speed gravel, I had to make a £75 windscreen claim after a very small crack that was apparently too big to fix. The silver lining was that the new screen came with a new sensor attached so at least my sensors work now but stuck with a non oem windscreen
This past week was rather rainy here in NoVA, so I was able to experiment a bit and found that the intermittent feature worked as advertised on mine when I pressed on the bottom of the cover. I took the assembly apart and found the transparent cover to be firmly attached to the windshield, thus no need for reapplication. Apparently mine was not delaminizing as previously thought. But this does beg the question: why would pressing on the bottom of the cover cause the unit to return to full functionality?
Thoughts?
Thoughts?
Loose connection?
Good evening! I know the thread is a little old but thought there wouldn't be a point in starting my own as my circumstances are so similar. I have the same problem as the OP the adhesive section has come away thus messing with the rain sensor functionality. The lights to note work fine (turn on at night and off during the day).
I'm not too bothered about the rain sensor function. I'll be happy if it reverts to standard intermitent without the sensor. So I discounected the rain sensor module. This solves the wipe issue. However now I'm left with lights on all the time? I'm not 100% certain of this because it's dark now, but I know this is probably because I removed the sensor, and naturally makes sense.
So my question is, can you deactivate the rain sensor function (with coding or something else), but retain the light sensor functionality?
And if so, can this be done without coding? For example you can program a new set of keys yourself, without any tools.
Many thanks!
Quick update the lights definitely stay on during the day if you unplug the RLS module. Also if you remove the fuse, it does exactly the same as if you unpluged the module (possibly a tidier temporary fix to those interested).
Will now explore the coding route. Watch this space.
I bought a new adhesive pad and re-attached the rain sensor to the windscreen. Works great now and was pretty easy to do. Just make sure to thuroughly clean before attaching!
