JamesUK
'Evening all,
Weird problem, that I'm hoping may have an easy solution...
Suddenly, my radio will not react to most controls. So, it's stuck on radio 1, it won't react to the volume knob. When I press the numbered buttons, they display the presets that I have, but doesn't change channel. To turn it off, I have to press off 3 times, very fast. Taking the key out of the ignition no longer turns the radio off.
Possible causes:
1. New phone craddle, which presses against the front of the radio (very unlikely I feel).
2. Using "Torque" Android app, which access the ECU. I also accidentally kicked the Bluetooth OBD out of its port (with ignition off). Stupid huh
3. Randomness.
Possible fixes:
1. Disconnect battery (although I don't have the radio code - if z4's have such a thing? My old e36 did, possibly my e46 too)
2. Dealer/BMW specialist
3. Remove radio - I'm concerned this fault could be draining battery too - only happened this evening.
Any help/advice/fixes appreciated!
James
2003 z4 3.0
Possible causes:
3. Randomness.
Possible fixes:
James
2003 z4 3.0
