Hi all,
Any ICE experts out there
I had to have the battery replaced on the Z3 last weekend which meant I needed to enter the anti theft code in my Becker Cascade Pro ICE. No problem, the code was written in the manual, however I entered the code in 3 times and its now locked and says device disabled. It was only then I realised the handbook isn't the original one that goes with the unit
Found the correct code in the box
. Anyways to get to a stage to enter the correct code in again you have to leave the unit and cars ignition switched on for an hour which is a bit of a pain.
Would pulling the fuse for the radio reset the unit back to code entry mode or does in remember that its in disabled mode, I'm thinking if theres no power at all it will reset the unit?
Cheers,
Tim.
Cheers,
Tim.
