Quijibo Jones
Hi All,
I have a coolant leak from the expansion tank on the radiator. It gets really bad when the car is up to temp and the source is what looks like a very fine hole mid way up. I can see a very fine high pressure jet coming out of the tank.
I've never used a sealant in the coolant system before. the question i have is will this work to fix the issue? Appreciate you can only go on my description but given how fine the spray is the hole must be tiny.
