I replaced the radiator and expansion tank a few months ago, I noticed that i now have a slight leak on the bottom hose off the rad. Having seen the post of replacing the bottom hose I thought i would share the quick and cheep way of fixing the problem.
Problem: O-ring worn on end connect to engine
Fix:
1.remove radiator cover
2. remove fan
3. disconnect hose to engine
4. disconnect hose to radiator
5. remove o-ring from inside plastic end of pipe (used knife to prise it out.)
6. ordered new o-ring from off ebay 38 x 4m pack of 3. cost couple of pounds
http://www.ebay.co.uk/itm/290734681870?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
7. fit new o-rings both ends
8. apply some grease to help the o-rings slide on.
9. reverse fit everything.
10. fill coolant up
Fix:
2. remove fan
10. fill coolant up
