Does anybody know the correct size radiator for an m54 manual engine with aircon and or recommend a decent make?
Autodoc isn't very clear on the correct size and whether it makes a difference if the car is manual or has aircon fitted,
I've got a slight coolant leak coming from the very front of the car but when the car is jacked up and idling I can't see a drop coming from anywhere so I assume its the radiator leaking once the thermostat is open and it's upto pressure and temperature. I've replaced the expansion tank and thermostat recently and all the pipes look fine so I'm pretty sure it's the radiator or maybe that bracket the bottle mounts onto
