Quick question re Rocker Cover Gasket Bolt Seals
junglist
Looking to replace my rocker cover gasket in the next week or so as I've discovered oil residue around the heat shield / CCV breather.
I've ordered an Elring gasket kit along with the recommended BMW sealant Drei Bond 1209, now I'm just needing the replacement rubber seals.
I've seen links to the Febi set on here - product code 24323 however these only refer to the lower engine models.
https://www.ebay.co.uk/itm/Rocker-Cover-Bolt-Rubber-Seals-BMW-E36-320i-323i-325i-328i-x16-FEBI-11121437395-/362163896789
Do they definitely fit the M54 3.0i?
Thanks.
I used exactly the same parts as you when i did mine, apart frpm the sealant. I used permatex.
I donr think u will gave any issues with those bolt seals but it wouldn't harm to cross-reference with realoem.com.
http://www.realoem.com/bmw/enUS/showparts?id=BT52-EUR-05-2003-E85-BMW-Z4_30i&diagId=11_2172
Looks like the part number is 11127838077 which is different to what the eBay listing specifies, looks like I'll be ringing BMW in the morning!
