Looking to replace my rocker cover gasket in the next week or so as I've discovered oil residue around the heat shield / CCV breather.
I've ordered an Elring gasket kit along with the recommended BMW sealant Drei Bond 1209, now I'm just needing the replacement rubber seals.
I've seen links to the Febi set on here - product code 24323 however these only refer to the lower engine models.
https://www.ebay.co.uk/itm/Rocker-Cover-Bolt-Rubber-Seals-BMW-E36-320i-323i-325i-328i-x16-FEBI-11121437395-/362163896789
Do they definitely fit the M54 3.0i?
Thanks.
Thanks.
