Question for those who use NCS Dummy/Expert
MalNCH
Old Costessey (Nr. Norwich)
I'm 99.99% certain I have this right but just checking with those who use it.
You load a trace file in DUMMY so you can view/change the check boxes for an option you want to change, you export the trace file (which has an extension of .man) and load it into EXPERT so you can actually change that option?
You use NCS Expert to connect to, read and/or download the module you want. This is a trace file .trc
You then open this TRC in NCS Dummy or notepad and edit the options you want. Then export/save the changes as MAN. Use NCS Expert to 'upload' back to the car and you're done.
Be careful with the NCS Expert options, the default job is SG_CODIEREN which will write to the selected module using the values in FSW_PSW.MAN
CODIERDATEN_LESSEN is read.
Thanks, that's the process I meant, you've explained it better than me.
Also pick the correct profile for the job - for most jobs I use revtors NCS dummy profile (ver4) which has manipulation enabled.
I'm assuming you already are using this profile - since you have NCS dummy.
If you start using other software to flash/program modules - make sure to put the car on good charger while doing so
