So for all those that remove their run flats and put standard tyres on the cars, what puncture / tyreweld kits / pumps do some of you use or could recommend ?
+1 otherwise it's a new tyre!AlanJ said:Several popular brands on the market BUT make sure you get a water based kit so that a repairer can wash out the gunk and make a proper repair if possible.
Stuartt said:AlanJ said:Several popular brands on the market BUT make sure you get a water based kit so that a repairer can wash out the gunk and make a proper repair if possible.
SLIME is very good and not too expensive, washes out with water so doesn't ruin your tyre. The AA used it for a bit before switching back to a temporary plug kit.
Alternatively give your breakdown provider a call, I can recommend a certain aforementioned company and sort out a bit of a discount on any new membership required![]()
Jollyjoiner said:Stuartt said:AlanJ said:Several popular brands on the market BUT make sure you get a water based kit so that a repairer can wash out the gunk and make a proper repair if possible.
Yes i've looked at the slime ones and can pick them up for £23
I'm also in the AA already so if that fails then it would be a call to them
Stuartt said:This is almost exactly what the AA use and it seems to work 99% of the time.
http://www.amazon.co.uk/STOP-DELUXE-TYRE-PLUGGER-KIT/dp/B003VE41OS/ref=sr_1_4?ie=UTF8&qid=1421607818&sr=8-4&keywords=tire+plug+kit
KERMIT1970 said:http://www.eurocarparts.com/ecp/p/car-accessories/car-accessories-products/emergency-and-breakdown/tyre-foam/?539771440&0&cc5_906
I had this one in my old e86. Still have it in the garage.
