Pondrew said:
Zforbes said:
If I understand correctly pre LCI cars like yours and mine have puncture warning systems rather than pressure warning. I believe this works using the wheel speed sensors rather than pressure sensor in the wheel itself. The flaw is slow reduction in pressure isn't captured. It works by calculating the difference in rotation and I think also the steering angle.
You can't rely on this sort of set up to detect a slow reduction in pressure, my guess is you've had the puncture longer than you think and you should keep an eye on your pressures like you should on a car without this kind of set up.
That's my understanding and open to be corrected
My LCI doesn't have sensors in the wheels.
My understanding was with all E89s it is a by-product of the ABS, by measuring rolling radius with each rotation. It may be different and may also be different on cars with Idrive that have a more sophisticated system.
Could be wrong. Won't be the first or last
Mine is a 64-plate, no IDrive, LCI. Has TPMS sensors.
I would double check yours. Just because there are standard valves fitted doesn't mean there should be.
Are you sure your system works?
A previous owner could have swapped wheels, or even fitted standard valves as there was a problem with the sensing system on the car?
Worth a double check any way.
Easy way to check would be to let a few psi out of one tyre and see if it tells you.
