Sohailnisar said:MrPT said:10mm spacer on the front axle is perfect with CSLs or reps with the same offsets.
I'm going up to 265/35 and 235/40 sizes to improve the ride/handling. Only done the rears so far. Looks like a sexy tractor!![]()
Got any pics?
Whats the ride like with these?
MrPT said:Sohailnisar said:MrPT said:10mm spacer on the front axle is perfect with CSLs or reps with the same offsets.
Got any pics?
Even with just the rear tyres changed it is much better than what I had before (275/30) on B roads and over expansion gaps etc. When moving to 19s I put the suspension to nearly full soft and the ride was acceptable, but still not compliant enough to handle sudden, small changes in the road surface. An 8cm sidewall is silly, in hindsight, but I wanted to keep the look of the 19s instead of moving to 18s.
Going to change the fronts soon too. It looks a bit odd, currently, but the main issue is the large difference between front/rear rolling radius, which could be affecting the DSC. Since I dropped the front to match the reduced arch gap at the rear, the car is also raked forward enough now that I've had to be more careful on speed bumps etc.
I'm not sure you will be able to do 235/40 and 265/35 without height-adjustable suspension, but 225/40 and 255/35 apparently works well. 245/35 and 265/35 might rub a little, but also looks like a good combination to go for since you have the added bonus of it reducing the factory stagger (helps remove understeer).
Beedub said:i run 18s on semi slick 235/40sF 265/35s R
Performance from this setup is fantastic, haven't noticed any more intervention with the DSC tbh but these have been on for a while.. Traction until warm can be limited , no rubbing at full compression, car is lowered only around 10mm from stock as you can see very conservative i can fit my hand right into the wheel arch , i wanted as much compliance as possible from the track based suspension setup, which mean travel needed to be retained, The tyre size give a lovely fat sidewall, which imo really suits the short and squat look of the z4M
From my experience this car behaves best on 18s, do lots of research before making your wheel choice.
Sohailnisar said:Beedub said:i run 18s on semi slick 235/40sF 265/35s R
I've not seen them wheels on a Z4M before - what are they?
I do agree - I did think 18s look better on a Z4M. But after seeing some lovely examples with 19s on I'm 50:50.
I don't want to break the bank either - 19" CSL Reps are pretty easy to come buy for a decent price. With most other stuff it seems to be £1k+. I guess the alternative is to leave it on the wheels its on with maybe a powder coat.
Sohailnisar said:Car looks lovely. What suspension set up here you running?
MrPT said:Sohailnisar said:Car looks lovely. What suspension set up here you running?
Thanks. It's on KW V3s - quite popular on here. Rear is at stock height; front dropped 24mm at the moment!
MrPT said:Really interesting to hear your thoughts. S2000 has a pretty cool engine too.
It does take a while to warm up, yep. Consensus seems to be that you should stick below 3k until the oil is up up temp at around 80-85C.
Gearbox is stiff - comparisons with the Honda usually aren't that flattering! 1st to 2nd needs to be either super gentle or super punchy. Anything in the middle tends to be a bit jerky.
3.5k could be Vanos rattling, although that's usually a little lower in the range. It's a horrible, gravelly metallic sound but is harmless. There was a service bulletin about it - SI B 11 05 06.
RedUn said:Remove the cdv, just like on the S2000. Helps a lot with the gear change
Ex S2000 owner 8)
Lower said:There are quite a few ex s2000 owners on here
I'm another one![]()
Sohailnisar said:Awesome, I'm loving the Z4M but I think I'd get another S2000 one day, loved that car.
You've got the isofix on your car - did this come factory fitted?
I'm having a baby in November - mine doesn't have it, thinking of getting it retrofitted. Just wondered if you've done yours and if you've got any tips?
