R.E92 said:It won't pass an MOT with the cats gutted but the good news is that if you don't have any cat related error lights then it most likely already has a remap installed.
Whistling noise is probably the turbos. If you have no mufflers or cats then you'll hear them.
Roddy said:Did you do the roof wrap yourself? More pics of that would be nice![]()
What are the wheel specs?
The car is stunning![]()
Nisaja said:R.E92 said:It won't pass an MOT with the cats gutted but the good news is that if you don't have any cat related error lights then it most likely already has a remap installed.
There are no CELs on the dash. There was a ECM code when we scanned it. Said 375C DME.
Is it fine to run these cars without cats? My other car is an RX7 and if you take the cat off that, it'll increase the boost. Will running with no cats do any harm to this car? I don't mind failing the MOT lol.
Nisaja said:That's great! I have nothing to worry then.
The car doesn't have mufflers. I checked when it was on a ramp. It's just a straight pipe there. It pops and crackles. I'm assuming the pops and crackles are due to the cats being gutted. It still has the stock resonators though. That's keeping the sound in check.
You're right about how bad this engine sounds. I know 4 cylinders sound bad, but this sounds like a diesel! It's so rattly. I've noticed that it's extra rattly in the morning, and it quiets down when it warms up. Is that normal?
R.E92 said:Nisaja said:That's great! I have nothing to worry then.
I'd want to get the mufflers fitted again, they should help mute the rattly engine sound without any reduction in performance.
The only real cure for the noise is getting a 6 cylinder![]()
Nisaja said:R.E92 said:Nisaja said:That's great! I have nothing to worry then.
Haha I wish. There aren't a lot of 6 cylinder Z4s where I live.
The rattly sound is coming from the engine though. Not the exhaust. I was a bit concerned, but I don't know much about the N20 so I thought it's normal
