enuff_zed said:As you can see from the photos, it's so much easier if you fit behind the seats.
Brilliant photos - I can see Ed coming in handy when access is limited!
I sent him in to sort the roof motor. No sign of him since, so I threw a couple of sandwiches in, locked the boot and went for tea.Mr Tidy said:enuff_zed said:As you can see from the photos, it's so much easier if you fit behind the seats.
Oh yeah! Forgot him.Mr Tidy said:Wait until his Dad comes looking for him!
Mr Tidy said:I hope the keys aren't in the boot with Ed!
enuff_zed said:Just a little update as not much has happened lately.
Had a panicked call from Scott (Ed's dad). Parked the car on his steep drive and when he tried to apply the handbrake it shot past his ear with no effect whatsoever.
At this point I admit I only sidled over lowly, fearing the worst.
Sure enough, up and down goes the lever, and apart from pointing out the location of the rear view mirror it was achieving bugger all else!
Stuart (bigwinn) was an immediate source of comfort! "Ooh that'll be the prop shaft and exhaust off for access at least!"
Not good news to someone with 2 axle stands and a gravel drive.
Anyway, never one to avoid grasping at straws, I pulled back the trim. Then I noted that the adjuster lever (which takes off the tension while you set up the clearances) was engaged.
Out came the BF screwdriver and I gave it a good old ping to move it.
Lo and behold, it popped off and the handbrake went back to functioning properly.
First action was to message Stuart to ruin his gloat-fest![]()
No idea how it engaged itself but thank f@@k! An easy fix for once.
Something to bear in mind if it happens to anyone else.
Go on, at least admit you were glad it wasn't you.bigwinn said:enuff_zed said:Just a little update as not much has happened lately.
Me??? Never
enuff_zed said:Go on, at least admit you were glad it wasn't you.bigwinn said:enuff_zed said:Just a little update as not much has happened lately.
Me??? Never![]()
But I must say thank you for at least answering my queries.![]()
