Problems with battery disconnection
RussellP
I need to disconnect the battery to swap my steering wheel, is there any adverse effects to doing this, I have read that the windows might not operate correctly after as anyone experienced this and how do you reset if they don't work after?
Thanks in advance..
Resetting the windows is easy, all you have to do is
Turn ignition on
Push the open window button until the window is open, then keep it pressed for 5 seconds longer.
Push the close window button until it is closed, then release.
This should reset the memory on the window and use the same procedure for both windows.
Turn ignition on
What he said. :D Worked for me anyway, although curiously last time I didn't need to do it, just had to reset clock as previously stated. Weird.
