Problem with locks
Torpalasse
 Sweden
The locks on the car is now broken.
Cannot open the car with remote, only with key.
Cannot open passenger door by any means.
My carly reader is in the middle storage between the seats, and its locked.....
How do I open it???
Open the boot and look at the rear bulkhead just right of centre. There is a black toggle there, pull it out and the string it is attached to should open the centre storage latch.
Failing that, a thin metal ruler or similar can be pushed into the top of the storage door to open the latch.
Got it open :driving:
When checking i got some errors, but the locks works fine again??
But still some error codes.
Bad battery?
The carly diagnosis
It looks to me more likely that the GM5 module is failing. A common issue with the locking relays inside it.
However, I would also check out the battery first.
Its going in the back of the garage for now.
Problems will be sorted next spring.
The oil level sensor? Something I need to fix?
I get warnings when the level go low, so it seems to be working just fine.
Oil level sensor can be changed when you do an oil change. What engine? Do you have a dipstick?
I had it for a while too, but it’s an inexpensive part and easy to do when changing the oil.
