Not Z4 related I know
but have a little problem with the Z3 which appeared maybe coincidentally after driving through a bad rainstorm. When I lock the car via the keyfob which sets the alarm after a few minites the hazard lights start flashing which stop when I unlock the car again. Luckily I can lock the manually with the key but a slight pain as I have to lock the passenger door from the inside as there is no key lock. I suspect its an alarm issue. Done some googling but there doesn't seem to be a common theme. I've checked the bonnet switch which looks OK but don't know what else there is to check. I'm thinking of removing the radio unit and checking the anti theft connection as I fitted it some years ago and wondering if the connector has worked loose. Apart from that I'm guesssing the alarm is shot? The alarm doesn't sound when the hazards are flashing.
Just wondered if anyone has come across this with BMWs.
Thanks,
Tim.
Thanks,
Tim.
