Thanks for the feedbackPawnSacrifice said:Just noticed you went to an indi, they'll be Pagid, or similar, rather than OEM.
Indi's tend to source from somewhere like http://www.eurocarparts.com unless you specify OEM. Ask them and I bet they confirm that. That said, Pagid have a good reputation so I wouldn't rule them out - just check what the warranty is. At that price, they're a good shout IMO.
Jimmy Gee said:I took it to a bmw specialist so just assumed they would use oem, do you know if its ok having one side oem and the other being an aftermarket caliper?
PawnSacrifice said:Jimmy Gee said:I took it to a bmw specialist so just assumed they would use oem, do you know if its ok having one side oem and the other being an aftermarket caliper?
Not entirely sure, but I suspect if they weren't I'd be expecting the indi to be trying to sell you two straight away - replacing in pairs / sets is a common cry from most garages. The piston should be the same size, the pad and disk certainly will be and they are running off the same master cylinder, they may even be made under license to BMW. You should be fine but I would ask the indi to confirm this.
I'd ask the question and have some time to consider it - if only because someone may well be along with better information :?
Half of its for peace of mind and the other because I needed one straight away. Ive actually had it replaced late this afternoon so im back on the road again nowpeddy said:What's wrong with 2nd hand? especially when you can have it for £65 (for both)?![]()
PawnSacrifice said:Nice work Jimmy Gee, what did the indi say about the compatibility? Obviously they are, but did they elaborate?
Interestingly the Pagid 3.0si calipers are about £105 a side. I'd have been tempted to pay the premium for new.
Jimmy Gee said:Cheers Gannet, Ive just had a look on that website and for one front caliper it came out at £359. That cant be right can it, well I bloody hope it isnt. Although I couldnt find the caliper as a whole unit and had to put the housing and carrier in as seperate parts then add the cost together.
