Presure plate "ninja star"
paulz
New member
Hello, I have a e85 z4 2.2l m54 engine for a while, and I was thinking that should be nice to don't have any oil leaks at all, I start changing all the seals, but when I remove the gearbox out I checked the clutch as well and I was not so happy about how was looking and I decide to buy a new clutch kit, everything went well until last moment when I put everything togheter, I bleed the slave cylinder(I replace it as well) and surprise, I can't press the clutch pedal, it is very hard to press and it is not working, so I can't put it in any gear, what I did wrong it was removing that "ninja star"from pressure plate before installing,there are any chances to fix this problem without changing again the clutch, or to get down the gearbox again?Thank you!
I got all detail from a Haynes auto fix online book, they were not even having any details about lot of stuff there, a waste of money!
Yes, you have to rest the pressure plate again. See YouTube videos on how to do this.
Yes, you have to drop the transmission again.
Only remove the ninja star once the pressure plate has been bolted to the fly wheel.
Ok, thank you for your answer, I have seen some videos about reseting the pressure plate, it is not very complicated, all I need now it is some time, I will come with news as soon as I can!
