Traxxer said:
cj10jeeper, on your seats, are their more plugs then the one I have? I'm thinking the only thing I won't be able to do is set the heat on the seats via he panel in front of the ashtray. If I remember correctly the seats have the buttons on the side.
Traxxer
I confess now to becoming more confused about your upgrade so let me step back and restate and see if it helps
There is just one loom and plug out of the floor that connects to the yellow socket you have on the seat
On the drivers side the seat side of the socket groups together any of the following you have:
Power input to the memory seats - all it's switches motors, looms being built to the seat
3 heated seat pad
airbag /seat tensioner controls
Passenger side
The same as drivers but a small control box to detect a passenger in the seat (and therefore airbags, seatbelts warning, tensioners, etc.)
I never took photos specific to this when I built mine but the 3 below may help you visualise without the need to pull the seat out:
Manual seat showing the looms grouped into the socket (note rear cover of socket is removed)
Manual seat frame with just the seatbelt loom connected
Powered memory seat frame with motor looms and seatbelt looms disconnected
If you count the wires in your loom where it comes out the carpet and tell me the colours I can look at mine and see if you are missing any compared to mine. If not then it's easy as you just have to sort the dash heating switches
Hope this helps
