Can't for the life of me get the inner bush far enough up the arm... Any ideas? The arms are MEYLE HD, I'm about half the width of the bolt holes out and have tried hitting it a lot.
Near the bottom of page 3 said:...
ratchet strap did the job perfectly - went on even easier than the first side if i'm honest!
simply hook both ends of the strap to the gaps in the control arm, take up the slack, then align the lolipop by hand.
push the lolipop on with one hand, then use your other hand to operate the ratchet, using it to take up the slack and stopping it from popping back off.
once you've pushed it as far as you can by hand, tighten the ratchet slowly until there's some tension, then give the lolipop a tap with the rubber mallet, and bingo!
