Power steering light / no power steering
Gjm91
 Southport
Hi all- Z had been left for a week without driving, been outside in mostly below freezing conditions- started her up today she started fine and moved her onto the road as i was going to fill her up with petrol then parked her and Moved my other car back onto the drive. Got back into the Z and started her up - the yellow power steering light came on and no power steering - drove round the block stopped and restarted -power steering light no longer on and power steering back working - drove to garage and then a 20 min blast and no further issues.
Anyone had anything similar ? Could it be related-to the temp etc? Any other ideas
Mine came on after a flat battery and stayed on £££, you may be lucky.
If it does it again, check the battery and also remove a battery terminal for a few minutes to see if it re-sets.
Cheers firebobby - did you need a new battery . Did that solve the power steering light issue?
No, just recharged the battery.
I did need the motor ECU rebuild (or what ever they do to them) which cost £300 to do. That's a hell of a lot cheaper than a new steering column and motor from BMW. :roll:
Cheers guys - going to the zed shed tommorrow for a new vac pump seal and new fogs to be fitted will ask him to check over the battery to see if that might be the issue - its a lion battery which seem to be at the cheaper end of the market - no idea how old it is either.
Did you manage to resolve the issue?
I’m experiencing a similar issue with the coding being lost when my car is powered down. It’s not the battery, as I have a new Bosch S4 which is trickle charged and giving 13.1V. My car (3.0LSE) was re-coded, MOT’d and serviced yesterday, all perfect, but this morning, when started, the EPS light is on, Sport button does nothing, and I have no power steering.....
Hi sorry to hear of your issues - think mine were down to the battery being in a low state of charge as when it happened she hadn't been run for a week or so - got the battery checked and was low charge but otherwise fine. A few longer runs seemed to sort it -Still not sure if i need a new battery as the car had only been left about 10 days without being run - hope you manage to get your problems sorted
Exactly what my car did.
When you plug it in to read the codes, if it says it can not connect to motor, it will need the skills of ECU testing.
Hope it's something simple though
See my other post of tonight. I suffered a critical EPS malfunction and had to have both ECU and motor re-built. A four-figure sum later, and my EPS is perfect, with no loss in memory (just no cruise control, but I think my indie didn’t realise my car had it...)
