Dr_Tripwire
kis said:flimper said:Is it easy to do? Any pics?
Yeah pretty easy. Depends how far you want to go, you could take the whole thing off if you wanted. But probably better left in situ.
If you're taking it off in situ, the mirror comes off (that's kind of complicated if you've never done it - theres a guide somewhere). Then some screws come out of the bottom and middle section of the mirror cover. This means the cover (2 sections) comes off and you've got access to the main body of the "mirror". It's actually quite complex to explain!
I'll repeat over the summer and take some pics then![]()
Hi Kis
Just reading through your posts - I've got this going on - mirrors go up, I can I get them to go down if I don't let them fold up completely, otherwise they fold up completely, then only the driver's side unfolds UNLESS I give the passenger side mirror a helping hand...it looks like it moves slightly but the mechanism is getting stuck on something, hence not not unfolding from completely folded.
I'll try what you've suggested (leaving the mirror in situ) but can I just ask, when you say the mirror comes off - do you mean the mirror glass with the heater element/mounting with circular fitment that you'd normally prise off when replacing the mirror glass?
Also the screws that come out of the middle and bottom section of the mirror cover, are these located behind where "the mirror comes off"?
I'd like to give this a try as the garage are saying that it might be the module that is located in the driver's door, but I don't see that being the case and think it's more a case of them needing a clean and lube!
Thanks in advance.
