maupineda said:MrPT said:
I have tried to figure out the actual loss if any, because even when the piston area is smaller, the pad is larger, without actual engineering studies (not internet excel sheets) is very difficult to accurately say what is, and what is not an upgrade.
I just installed the 6-pot Brembo and the feel is nicely improved, and have no way to tell if I have less brake power, I am still able to trigger ABS if I stomped the brakes just as before, yet, they are easier to modulate as the pedal is firmer the more you press it, whereas with the OE setup is always the same so your only feedback for modulation is travel.
Nice work. The advantage of a larger pad area is mainly heat dissipation and reduced wear rate. It doesn't compensate for smaller piston area in terms of clamping force on the disc.
It's worth spending a bit of time thinking about the calculations because messing with brake bias can be extremely dangerous.
