Hello All
I am battling with a little problem at the moment and I hope someone may have experienced this before or have some ideas....
Basically I have a strange popping/creaking noise coming from what appears to to be the drivers side rear. It very is very rarely heard under normal driving however when on a more spirited drive it is normally heard when cornering and on the throttle or after a corner getting back onto the throttle. It also occurs when you move into reverse after moving forwards and then again coming out of reverse moving forwards.
I captured this video by strapping my go pro under the car to help capture the noise. You may need to fast forward a bit as I had to drop the car off the jack after starting the camera. The worst noise, a loud pop, can be heard at exactly the 1.00 minute mark as I engaged reverse. I then later around 1.20 rock between 1st and reverse to show the noise ( please ignore me stalling it....
So far I have performed the following to try to resolve this:
I have checked that all anti roll bar mounts are torqued to the relevant levels
Checked all the sub frame bolts are torqued to the correct setting
I have replaced the rear trailing arm bushes ( front ones only)
I have changed the differential oil to ensure it uses the 'booster' diff oil.
Checked all exhaust mounts
Visually inspected diff mounts and bushes and all look ok
I am getting to the point I think it might be the diff, and praying it isn't, so if anyone has an ideas I of what else I could check I would be extremely gratefull.
Thanks.
Don
Thanks.
Don
