pilchardthecat
Active member
Since my car is my daily commutor i doubt i'll be able to pull my ECM (required for some of the testing i expect.... just had a quick scan of that doc, might get a chance to read it later)
"The ECM monitors a feedback potentiometer located on the actuator shaft (arrow) for actuator position/plausibility (closed 4.5v - full open 0.5v)."
If you can relate taht voltage to the data logger.
My expectation would be that "full open" voltage you would see either
- the actuator shaft/lever position at it's physical limit which is <100% WOT
- the actuator shaft short of it's physical limit implying that there is a decoupling of the physical range with the voltage range
there might be another pot on each individual throttle for which the same applies
