R60BBA said:Smartbear said:The owners must have ignored the rough running caused by the leaking injector & just driven on regardless :roll:
Not heard of a single case of it with the n20 here, only on the n54 engine.
You don’t know that for certain mate, also just because it hasn’t been mentioned on this forum doesn’t mean it’s not an issue on the N20 engine. After all the N20 was also used for the 2 Series, 3 Series, 5 Series and X Series...
Perhaps, inspecting and or replacing injectors should come under preventative maintenance items on these.
I’m fairly certain that if an injector is leaking enough fuel to destroy the cylinder (which was the suggested fault) then the engine isn’t going to be running as smoothly as it’s supposed to?
The 20i range of z4’s has been made for long enough to tell if something’s an issue or not, I’ve never heard a single instance of injector problems on these engines, they’re different to the 35i/35is versions which are known for leaking fuel.
