pilchardthecat
I have £2500 in my cancelled-warranty pot....tomscott said:+1 on the warranty just renewed mine £80 a month so worth it IMO
ga41 said:greddyl30pjg says that you shouldn't do it unless necessary, well i did just that and look what happened. You constantly hear people saying, I can hear a faint tick or grind or whatever and most answers usually are, "that's how the S54 sounds like"
bigdog said:Gutted for you ga41
But. I don't think that this is some sort of trend. I don't recall in my 3 years of forum membership. Hearing of any engine doing this. Like most newer cars. The biggest problem area is electronics & electronic subsystems. Not the engine internals.
Oil analysis is a very good way to track the health of your engine. But. One needs to do start doing this from when the engine is fairly new. So as to establish a baseline. Tin, lead, copper is what shows (mostly) for rod bearings. It can save you money. If one is easy on the car. You can lengthen the oil change intervals based on the lab results. I did this for the ten years that I owned a lorry company. In the US. It's less than a tener for a lab test.
pilchardthecat said:Is the risk increased by the frequency of "max revs" moments?
If so, i'm fucked.
pilchardthecat said:The corollary to that is - why buy a high-revving powerful car if you aren't going to rev it?
No point getting an M though if it's just the aesthetics, the non-M is 99% the same externally. In fact with the coupe the 3.0 looks better from the frontRubyBlueZ4MC said:pilchardthecat said:The corollary to that is - why buy a high-revving powerful car if you aren't going to rev it?
It looks nice![]()
pilchardthecat said:No point getting an M though if it's just the aesthetics, the non-M is 99% the same externally. In fact with the coupe the 3.0 looks better from the frontRubyBlueZ4MC said:pilchardthecat said:The corollary to that is - why buy a high-revving powerful car if you aren't going to rev it?
It looks nice![]()
I enjoy it.ga41 said:Well... mine has certainly had plenty of max revs moments... also read this thread by "pal", he may be a member here too, describing his second(!) bearing replacement on his car http://www.zpost.com/forums/showthread.php?t=883939
