Pin 12 trick
Cradley chief
 West Midlands
Hi all,
Does anyone know if there's a video of the pin 12 trick to open boot. I'm about to have a go and i don't want to blow the car up. I have a booster pack a wire with a test pin and a 7.5 amp fuse in line .
However, if you have an android phone or tablet, you can buy Binnergeek ProTool. With a single click you can open the boot. Plus you have a BMW specific Diagnostic tool to determine why the boot is not opening.
pretty hard to blow the car up, you just “touch”:oor wipe pin 12 to the fuse.(the big blue one) doesn’t matter which side.
Cheers.. I hooked up a button to it for while working on the roof.. glad I did, I must have pressed that thing over 100 times..
I was having troble getting the connector out. I didn't want to break anything,, so, I found the light grey/green wire, shaved a bit of the cover off and jabbed a test pin into it. I then heard the sweet sound of the boot unlocking and did a little dance.
I just have to fix the roof pump motor now.
Thank you to all who helped.
afirm Sir.. I did rather think also prob need a mech release as if the boot lock motor switch has a malfunction, you will be REALLY up the creek without a paddle...
The roof pump motor is what I was originally trying to fix. The boot was full of water and corroded the motor and distribution board. I disconnected everything, and like a pillock, I shut the boot.
