Phone Mount Recommendations
Gwest44
Sheffield
The roadster has an aftermarket Auxiliary port and the carbon structure dash.
I'm after something that doesn't block the air vents - any suggestions please?
I always use these Garrie. Easy to install and good positioning
https://www.co-star.co.uk/1185/dashmount-bmw-z4-2006/
I'm a big fan of the Quad Lock stuff as I also ride a motorbike. I find their vent mount a tidy solution.
I second those sentiments exactly. It's the only phone mount I'd buy now. :thumbsup:
I use the Co-Star mount too. Bit of a faff fitting it but it's solid and doesn't block any vents.
Brodit - used in all of my Z4s : https://www.brodit.co.uk/brodit/vehicles/bmw/z4/proclip-for-bmw-z4-0308-rhd/4964
Choose the proclip for your car, which is custom designed to fit on your dash. Then choose the mount for your phone type - this just screws on, so if you change your phone you just need to change the mount. I do not change my phone often :oops: They do adjustable mounts so they will hold a phone in a skin/case.
It sits to the left of the heater controls, which you can still easily get to, and it does not block any vents.
