blunderthumbs said:Penelope said:These are really good and don't look ridiculous when your phone is not attached like the big brackets do... Clips into air vents! YOSH on eBay
Do you have to keep removing the phone from the case every time :? you put it on the bracket ?
Hi, could you use this with any kind of case on your phone. Doesn't look you can adjust the width of the part that will hold the phone secure... welcome your thoughtsoldgitdave said:Take a look here https://www.brodit.co.uk/brodit/vehicles/BMW/Z4.htm. I've been using one for a while & they're pretty good to be honest.
Z4paul said:Hi, could you use this with any kind of case on your phone. Doesn't look you can adjust the width of the part that will hold the phone secure... welcome your thoughtsoldgitdave said:Take a look here https://www.brodit.co.uk/brodit/vehicles/BMW/Z4.htm. I've been using one for a while & they're pretty good to be honest.
Yes, thanks for your thoughts. This looks like a more helpful page on their website, I can see these should adjust to a degree and helpful to know it works well for you. Cheers. Pauloldgitdave said:Z4paul said:Hi, could you use this with any kind of case on your phone. Doesn't look you can adjust the width of the part that will hold the phone secure... welcome your thoughtsoldgitdave said:Take a look here https://www.brodit.co.uk/brodit/vehicles/BMW/Z4.htm. I've been using one for a while & they're pretty good to be honest.
Hi, mine is one of these so is adjustable https://www.brodit.com/product.html?id=511307. I've always used very slim fitting cases & found that once you set the width it holds the phone in its case perfectly. Hope that helps.
I managed to break a standard head unit! To be fair, I did push it in a little firmly when a CD was in the player - before then it worked well, was perfectly placed for mounting satnav and CDs would play fine with the mount in place. I have tried the mount on another zed with the standard head unit, but it is way too loose and wobbly - yet was fine on the first car :idunno:Timmyboybunter said:parabolica said:I have a reasonably-priced CD-slot mount. TBH I've never used the CD player (not the single slot on the dash of the changer in the centre storage) so works perfect for me. I remember someone one here saying they used one then their CD player broke and were linking the two together, but I can't confirm nor deny.
Me - yup, the owner of the company reckons not compatible with nav head units, which sounds too generic to be correct.
Either way, it broke the loading mech on my E85 nav unit - people with the standard one report success however.
Sidewaze Samm said:I managed to break a standard head unit! To be fair, I did push it in a little firmly when a CD was in the player
