PB Black Hole Advice
RJ595
Afternoon All,
I am after some advice with regards to Poor Boys Black Hole. I recently purchased some to try and improve the swirls on my Deep Sea Blue E89 but am not 100% sure on the best method to achieve the dazzling results in the reviews. Instructions on the bottle say, work until shiny, allow to haze and then buff off, but I struggled to achieve "shiny" and it didn't appear to haze as much as expected either.
Does anyone have some process pictures, showing the different stages? Maybe an idea of how much should be used per panel and "hazing" time required.
Cheers,
It won't cover swirls that much, but it is a good product. Don't expect miracles.
Has it been moist when you've been using it?
It's usually very easy to use.
I tried using it a couple of days ago (made the most of some dry weather before winter sets in). Gave the whole car a thorough 2 bucket wash, clayed the bonnet, rinsed off and dried, tried some black hole on part of the bonnet and then gave the whole car a wax. Difficult to tell the results as it was 7pm by the time I finished and raining ever since!
I haven't necessarily had any issues with it, just didn't seem to achieve the stages that the bottle suggest. Maybe it needed a little more working to shine up and then haze properly?
Essentially if you clean the car and then just add wax you are sealing contaminants. There will still be remnants of old product, sealant, tar etc so you want to get it back to the clear coat with no contaminants by claying. If you have clear coat issues like swirls and scratches you should use something like ultimate compound with a DA to smoothen out the clear coat, then polish to get a deep shine and then seal with wax which adds the mirror deep contrast but also seals the paint. Worth using a man made synthetic wax for long lasting protection this usual lasts 6-12 months then go over again with a natural wax which you can top up every 1-3 months or every wash.
PB black hole acts like a plaster to mask issues until you can resolve them as above.
hi have used poorboy products for some years now use black hole on both the e85 and a 25yrold 318is coupe both cars are metalic blue i find the deepest shine is not to let it haze and use a d a polisher on lowest settings try on one panel and see how it looks :D
Time moves on & there are better products on the market now . I'm by no means a weekend semi pro detailer :oops: but i do like to see good results & appreciate a decent finish
Have you given the paint a good base by using clay bar or mitt first or given it a decent clean with something like AutoGlym SRP or Autosmart Topaz ? Or in very hazy areas Meglars ultimate compound ?
That's how i would start , then id apply the PB bhg thinly ( or i prefer 50 cal filler glaze https://www.amazon.co.uk/50-Cal-Cover-Up-Filler-Glaze/dp/B00W5Q8HJS/ref=sr_1_1?ie=UTF8&qid=1539369252&sr=8-1&keywords=50+cal+filler+glaze)
Then when happy seal it with Auto Finesse Radiance carnuba https://www.ebay.co.uk/itm/Auto-Finesse-Radiance-Carnaube-Creme-500ml/263744635033?epid=731478108&hash=item3d6867c099:g:cIYAAOSwlY1ZIuNB:rk:2:pf:0
or Fusso 99 dark https://www.ebay.co.uk/itm/Soft99-Fusso-coat-Dark-PTFE-Car-Wax-NO-IMPORT-DUTY-JDM-FAST-NEXT-DAY-delivery/161750751750?epid=5007475561&hash=item25a9189a06:g:j7oAAOSwoX5apWih:rk:2:pf:0
The deep sea blue paint on E89 will give you great rewards if you throw in some effort & decent products , its not unlike Montego or Midnight blue on previous model Zs , both of which ive owned & had great results cleaning / polishing :thumbsup:
Thanks for all the advice. As I said in a previous post, I did give it a good wash and clay before trying the black hole.
Just been out to the shops and got to see it in daylight for the first time since applying the black hole. I must admit, it looks like a much deeper colour in the areas it has been applied and looked stunning as I walked back to her. Just wish I could see the results glinting in the sun rather than all this rain!
