Passenger side window problems
Brewchap
I'm having problems trying to roll up the passenger side window using the driver side switch. I can roll the window down with no problem, but can not roll the window up. What makes it more confusing is that if the window was half open, trying to close the window, results in the window going down. No matter which way you toggle the switch, the window goes down.
Good news is that using the passenger side switch the window works correctly up and down. On a side note I did have the G5 module rebuilt due to the door locks not operating correctly.
Any idea what I need to do to fix this?
I have this exact problem. Mine started doing it after I tried the “routine” to reset the one press close function. Since then I’ve been able to roll it down from the drivers side, but the only way to roll it up is to use the button in the passenger’s side.
I was just about to suggest resetting the windows but maybe that won't help.
I doubt it would hurt though... Famous last words.
Problem solved. I pulled the master switch apart and found that the gold contacts had some crud on them. After cleaning, windows works as they should.
