You may remember my last thread about my sodden passenger footwell (behind and in front of the seat) I found a leak in the door membrane allowing water to come in to the car and soak the carpet and floor. In the process of this I also changed one of the door seals.
However, my problem seems to be worse again, but the door membrane remains fine and I am at a loss as to where the water might be getting in. Is there anything/anywhere roof related that could be causing the problem?
Any suggestions on where to check would be much appreciated, this issue is a real ball ache and seeing the windows covered on the inside with condensation every night is so annoying!
