Passenger airbag sensor
Bmwjay
Advice needed
So Athena air bag light was on and kind of come on after I refitted the steering wheel BUT that’s not the case I got a diagnostic done and it’s thrown up a “incorrect Sensor used on passenger door airbag “
Weird as I have been no where near it
The car had been jumped started but that said it come on after about 3 days after
did you disconnect battery for over 20 mins before unplugging steering wheel airbag? if not that would send the light on, however when doing a diagnostic it might be storing a previous issue in it memory, you need to clear fault and run test again to see if it comes back with same fault.
