Jimbo.D said:
After a few days of driving. Idiot light back on most of the time. When its off at start up, steering is fine until it lights up. Talked with the previous owner, and he mentioned a vacuum leak? Doesn't make sense with an electric unit but I am clueless. No sport button on this car.
I suspect the only vacuum involved is between the previous owner's ears.
Still really need to see if a diagnostic tool can communicate with the EPS ECU.
At this point it could be the steering angle sensor, the torque sensor or the EPS motor.
Torque sensor would usually fail when you put a steering input in.
Steering angle sensor tends to either work or it doesn't.
The EPS ECU is prone to heating up and failing internally. It sits right on top of the motor as an integral part.
My money would be on that tbh.
In the UK we can remove the motor and send it away to be repaired, and it comes back with a lifetime warranty.
I believe they will deal overseas too, but not sure if it would cost too much.
If you can find a good second-hand motor to swap in it should work ok without any coding required.
Plenty of discussion on here on how to remove it, but bearing in mind most of that relates to RHD cars. Not sure what the differences are, but I do know the motor sits to the left of the column whereas ours sit to the right. Same component though: it has two sets of bolt holes depending which side it is to be fitted.
Motors aren't too heavy. I could bring one as hand baggage
