portculisz4
Having just failed the MOT with ineffective handbrake (less than 50%) I have just removed both rear discs and found severe corrosion on brake pads and inner disc surface, so just about to fit new parking brake pads and new discs. I have a question relating to the item referred to as the Parking Brake Cable Service Lock', what exactly is this and what is its function in setting up the parking brake adjustment ? I have read the Pelican Guide on enabling/disabling the lock but it gives no explanation as to why this needs to be done.
My parking brake adjustment with the old disc and pads appeared to be OK (3 clicks to enable the brake) but the brake was just inefficient for obvious reasons, I was hoping just to replace the necessary components and then adjust through the wheel as per normal procedure, do I really need to do any adjustment at the handbrake end ??
