My park brake on my 2005 E85 has got to the point in needs adjusting.....near my armpit on a slight hill.
I fully understand the how to do it and have the tools and knowledge to do it, so why you may ask am I posting?
I started the procedure by moving the hand brake gator and trim panel as per numerous procedures on here and else where.
My problem is that the cable self tension mechanism wont budge. The you tube clips I have seen don't seem to need much effort to push it towards the rear of the car until it latches. I have put quite a bit of pressure on it via a long screwdriver....until the veins on my temple pop out.... :x
Mine just wont budge. Im reluctant to use my usual brute force and ignorance technique in case I break something expensive.
Any one had a similar problem? As this isn't normal. Should I break out a hammer, got a few in varying sizes.
