look at the fuel trims before spending out a grand for a new manifold cat,you may need to get a more accurate reader ..
that way you can see if its over fueling or under fueling,these engines are very sensitive to vacuum leaks, the cat may be clogged from this and may be salable. check your oil filler cap has a good seal,and you have the correct level of oil.
These engines also run a oil vacuum pump from the rear of the engine that can cause issues if its not performing well(blocked leaking ect).
if you do need a new cat there's a member on this site,ducklakeveiw.. who seems to be able to source second hand csts for this car
but do some tests on it first to make sure its the cats and not a vacuum leak.
hope this helpsi ve been there,
with my 2.0l
got told by stealers it was a buggered cat,but it wasn't,
