Hi all,
Had my first problem with my Zed today. The overheating light pinged on and I noticed the temp was running high at about 100/110 degrees C. Care went into limp mode but managed to make it home.
The fan appears to be running ok, and the coolant level is topped up, so any ideas? I've started the car with the coolant cap off and get a steady stream coming through the 'peep' hole which would indicate the pump is working?
What is the normal running temperature of these cars? 2014 e89 20i
Thanks!
Thanks!
