Afternoon all,
2003 M54 2.5 -
I had anoverheating issue on the way home just now. The coolant light came on just as I'd pulled up at traffic lights. I immediately noticed a puff of steam from under the bonnet and very quickly drove on to a layby a few hundred yards ahead. Opening the bonnet I see there is moisture beading around the header cap and coolant clearly sat around in the undertray. I had no choice but to limp the two miles home gently. The odd thing is that the gauge never moved from the middle. I put the heater up to full and only had hot air intermittently so either the auto climate was regulating this (doubtful when on max?) or there was a circulation issue.
The belt is all fine as I renewed them (both) a week ago. The coolant level was also fine when I checked it on Saturday. Incidentally I read the codes (by coincidence) on Saturday and found an old P1622 'Map Cooling' code which I understand is thermostat failure. So I'm guessing water pump/thermostat at fault.
I'm resigned to cracking on and replacing the radiator expansion tank, cap and thermostat, and doing the water pump for good measure, but can't understand why I didn't see the gauge move. Any ideas/guidance on diagnosis welcome.
Incidentally, i was driving back from main dealer after a full KDS wheel alignment and air con service. The car hates me.
Saturday I spent all day cleaning the interior and got an airbag warning light for my reward. Probably from crawling all over the seats.
My car obviously isn't happy with all the attention it's getting!
Thanks,
Behr.
2003 M54 2.5 -
Thanks,
Behr.
