Outer fuel cap
W16LSH
New member
Hi everyone, just wondered how you tighten up the outer colour coded fuel cap. Mines a bit loose.......
I put a couple of very small blobs of JB Weld black RTV on the locators and slid it back on the plastic hinge. :thumbsup:
I pulled mine off because the spring detached. Simple enough and then popped it straight back afterwards.
Once you remove it you can see if anything looks wrong, if it's broken then I'm sure a replacement isn't expensive. Got a spare one myself, that I picked up cheap. I don't mind taking some pics to compare if you've got yours out and you're stuck?
