Jonny essex said:No chance too common :fuelfire: lolTonyP said:Jonny, please buy a set of CSL's so that I can buy them off you cheap when you decide you don't like 'em :wink:
Common because they sooo suit the Zed shape
Jonny essex said:Well the 8.5 and 9.5" have a ET of 40 and im worried the fronts will rub like they did on et35 which resulted in rubbing away some wheel arch, what do you think Dave?Dav the wheel nut said:So you going for 8.5s and 9.5s or the pussy 8 and 9soke:
Dav the wheel nut said:Jonny essex said:Well the 8.5 and 9.5" have a ET of 40 and im worried the fronts will rub like they did on et35 which resulted in rubbing away some wheel arch, what do you think Dave?Dav the wheel nut said:So you going for 8.5s and 9.5s or the pussy 8 and 9soke:
I agree but 5mm spacers on the fronts should sort it or maybe these if the offset is really 35 on the fronts.
lux said:Mo, they look ace, never seen these pics before. :wink:
Jonny essex said:Im goin with 8.5 x 9.5 et 40 then the fronts wont rub as i want new wheel arch trims as both worn on the edges, then stick a 15-20mm spacer on the rearDav the wheel nut said:That is correct.
Perhaps you should stick to the wheels you know![]()
ben g said:Jonny essex said:Im goin with 8.5 x 9.5 et 40 then the fronts wont rub as i want new wheel arch trims as both worn on the edges, then stick a 15-20mm spacer on the rearDav the wheel nut said:That is correct.
Mate, a few people on here (including me) have 255/35/19 tyres on the front which stops the rubbing on 8.5'' front wheels.
They do give sod all rim protection though.
Jonny essex said:Ordered the 313s this morning......6:30am![]()
Same as last set in gunmetal with polished faces, should arrive Tuesday then fit following monday with drilled break discs too![]()
