Orange Peel??
The bonnet looks to have been blown over at some point, there are not that many stone chips, and the orange peel is pretty much all over the bonnet. Having said that bmw paint quality is not good, my neighbours 2017 x3 has similar orange peel, so it possibly could be the original but doubtful. I thought if you leaned hard on a DA it slowed down so surely it must polish it less? Dont want to go through the clearcoat but attempts so far have not yielded much change.
It depends
You can certainly stall a DA or rotary for that matter if you lean on it too much , it depends on the motor in the machine.
It’s a fine line, skimming across the surface with no pressure will yeald next to no results if your trying to correct heavy defects like orange peel..
Like you say, modern BMW paint is awful for orange peel straight from factory, I’m not sure how they get it so bad and the effect amplifies if the colour is darker
I have to hand it to you guys who are brave enough to declare war on your your paInt work , I'm afraid a cloth and Autoglym resin polish is my limit , good luck , may the force be with you . :(
Detailing becomes a bit of an obsession, and if it works the results are amazing. I now have a cupboard full of products dozens of pads and 2 DA polishers, where will it end?? :?
Wet sand the paint first, careful near the edges. 1500/2000/2500 and even 3000 if finishing with an orbital.
Orbital polishers take a lifetime.
Set aside £250 to have the bonnet repainted :wink:
Whereabouts are you pal. I will help out if not too far.
Ealing ! Its about 100 miles away, waiting on the menzerna heavy duty 300 polish but if that does not do it, any help would be much appreciated I could get to you easily enough
No worries. Drop me a PM if it doesn't work out for you
Russell
Bluecat, I'm about 5 miles the other side of Dartford Tunnel into Kent . I have been a S.M.A.R.T repairer for many years. If you want to come to me I'll take a look at your paintwork and offer you very good advice
So eventually got the menzerna super heavy cut and a flexpad denim pad. The results as below, hard to tell whether its actually improved the orange peel or just made it shinier!. Its hard to show it in a photo but the below does catch some of the problem, should i just suck it up or get it wet sanded, and if so by who and an idea of cost would be very helpful
really tricky one...honestly, in my view for a £5k Z4 you have to ask is it really worth spending £1k to 100% perfect the paint. The car looks amazing from what I can see, is that not enough?
check the depth of the paint first before anything. You've tried to cut it twice now with denim pads and course polish. I would not want to put 2000 grade wet & dry on that without a measure of the clearcoat.
Unless of course you are willing to spend on getting it painted when it all goes wrong.
As someone has already said the orange peel will be the lacquer. You need a block and 2000 w n d. A machine polish with a cutting compound will sort that out. Perhaps you need to get someone that knows what they are doing.
If there's any clear left after all that polishing.
Well its a 10k car :D but would have though colour sanding a bonnet would be at most a days work. Agreed re the depth of paint but surely if a bonnet has been repainted its unlikely to be a bare metal respray so there could be 2 lots of basecoat then clear coat on it so it would be still easy to go through the clear coat. Lynchy can I pm you re this??
Yes you can
Ok After much pondering ordered some 1500 and 3000 grit Trzact discs with a soft foam insert to go on the DA. It is possible to wet sand with a DA but you have to just use a water spray mister on the pad and a couple of squirts on the panel. Below are the attempts so far with 1500 grit doing quarter of the bonnet a time. I know have half a matt bonnet, will press on with the rest tomorrow then 3000 grit. Then the final stages are compound and then polish. If I dont post any more photos its all gone horribly wrong :? NB the first photo is the last, not got the hang of posting pictures very well yet. The third and fourth photo show the extent of the orange peel.
2018-08-11 17.31.25.jpg2018-08-11 16.30.40.jpg2018-08-11 16.06.31.jpg2018-08-11 16.05.52.jpg
