Big improvement
LMAO at the fitting of the centre light. That really should be a <5 min job. with a socket.
Beancounter1980 said:What are peoples opinions on Sapphire Black?
Standard or White Spots?
That was my thought too... though as far as I'm aware newer cars are required to have this third brake light, and it's to be within a certain height in relation to the rear window?Dreamer said:The only reverse light solutions i could think if you were to keep your current setup would be to put white alternate LED's in the thrird brake light that make it light white when you engage reverse...
tomTVR said:Ill admit it looks a mess but it works. I used sellotape because it does the job best without being visible through the clear lens. I had to use a halogen bulb due to the minimal space to work with inside the cluster. I would like to have constructed a nice fancy bulb holder but due the heat generated from halogen this would be difficult, particularly while keeping it invisible. Also I am not a keyhole surgeon, remember it would all need to be done through a bulb sized hole!
CJ - I see from your other projects that you like to engineer them perfectly. But my setup looks and functions every bit OEM and I have no reason to question its reliability.
That said if you can suggest a better way to stop the dashboard bulb failure light from triggering then I would like to hear it so I can give it a try. Perhaps bridging the terminals with an equivalent resistor?
