So, was drying out headlight, investigating none working headlight and fitting new ignitor as other had broken clips. Managed to dry headlight, will see how long for! Ignitor fitted but no joy, so went to remove ballast to swap and 2 of the 3 bolts sheared off. So ballast is off and sounds full of liquid, looking for replacment now. But need to look at how to secure the replacement. The sheared bolts have course thread into plastic, I'll need to try drilling out very slowly, unless anyone thinks 1 will be enough or has another suggestion? Trying to avoid breaking the plastic mounts so need to drill out slowly so it doesn't over heat.
Also found leaking headlight washer so need to order one of those! 1 step forward...........
